RCU Forums - View Single Post - beginner rockets
Old 09-02-2022 | 01:54 PM
khodges
Originally Posted by beatsal
Thanks. The 1/2A3-2 you mentioned - wonder which parachute to match it to? Guess the 1/2A3-2 is an Estes and the 2 is a 2 second delay.
You should bone up on the NAR engine classification, which is based on the total impulse of the engine. An "A" has 2.5 Newton-seconds of total impulse. The first number after the letter is the average thrust, also in Newtons, followed by a dash and a 2nd number, which is the delay in seconds until the ejection charge fires. This engine code applies to all makes of model rocket engines, and the code can be applied even to space rockets, but they are far in excess of a "Z". Once you get there, it starts over, doubling the letters, tripling, etc.
Every letter is double the total impulse of the letter before it. Example: your A8-0 has a total impulse of 2.5 Newton-seconds, the average thrust is 8 Newton-seconds, and it has no ejection charge. How can an engine with a total impulse of 2.5 Newton-seconds have an average thrust of 8 Newton-seconds?. Divide the average thrust into the total impulse (2.5/8) and you get a result of 0.3125, which is the thrust duration, or the length of time the engine burns, in seconds. The last number can be from 2 to about 10-15 seconds, depending on the total impulse of the motor. a "0" in the last position of the code indicates no ejection charge. Black powder motors with a '0" burn straight through, designed to ignite an upper stage motor. They will also melt a parachute if one is there.
A "B" will have 5 Newton-seconds (shortened to Newtons), a "C" will have 10, a "D" will have 20, and so on.
What is a Newton-second?
how many pound feet in a newton second - Search (bing.com)
Your rocket should be fine in a field the size of what you describe, as long as you launch vertically and have little to no wind drift. As the weight of the rocket increases, a given motor will give less performance, so a heavy rocket won't fly as high as a light one, using the same engine. A low thrust engine will burn longer than a higher thrust engine of the same total impulse. As the total impulse climbs in the higher letters, an engine may not make the full potential of the next letter, so it is called a "partial" whatever letter it is assigned.
Without knowing what rocket you launched, I'd guess anything from a streamer to a 12" parachute would be enough in your situation.
In the late 1980's and into about 1993, I flew high power rockets, this was before you had to certify at different levels. My highest power engine I used was a full "L", and I got a bit over 8500 feet with a 1/4 scale Honest John that I scratch built. It used a 48" parachute, and took almost 5 minutes from ejection to touchdown, and drifted 1/2 mile from the launch site, into a soybean field. Our launch site was about 3/4 square mile of open pasture and crop land, in eastern NC.
Cecil Webb (09-17-2022)
