Tony Coberly
<[email protected]>
To:hubert
Tue, Sep 6 at 8:26 AM
You can use a 553 for your needs. One thing you need to consider, is when the boat is powered up, it MUST be level. The gyro will learn the orientation, and it will try to maintain the same orientation in the water.Tony
This answer is direct from Futaba.
I know good and well this 800.00 Surface radio better do something as the surface flagship. It better do basically whatever I want or ill be quite irritated.
Regards
Hubert
