RCU Forums - View Single Post - Ziroli SBD-3 Dauntless build
Thread
09-06-2022, 01:11 PM
132
BatteryBob
Working on the outer panels. Needed more rivet glue but couldn't find the bottle of Rustoleum Sterling Silver - expect that to arrive in a few days. Also needed more 2mm half round for the hinges.
Got the hatches laid out. Checked for fitment in between rivets. You might want to reverse the order. Decided to move one of the lines running from the root to tip based on my scales references.
With glue drops added but still need the hatch rivets.
Moved over to the other panel to add the hatch rivets. I've found that I may need to take the panel inside (lower temp/humidity) to prevent the existing rivets from sticky to my arm and pulling off.
Reply
Like
BatteryBob
View Public Profile
Send a private message to BatteryBob
Find More Posts by BatteryBob
View iTrader Profile
