Its not an odd fire twin Bert, its an even fire twin... Clarence states that in his review... the crank journals are set at 30 degrees, cam timing is setup same as a even fire twin... if it was an odd fire, it would have had the Saito signature dual carb setup they use on all their odd firing twins... I would suspect the aggressive valve timing, and glow plug ign.
