RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-06-2022 | 05:52 PM
  #678
Cat 1's Avatar
Cat 1
Originally Posted by Raleighcopter
do you need any photos and measurements of my mounting plates or are you going to wing it? just let me know if you do. by the way, the magnum mount is slightly longer (or maybe it's shorter) than the os ft120 mount even though they are interchangeable. the cases on both engines are the same length though so i swapped mounting plates when i swapped the ft160 in for the ft120 on my rv8.
...it miight make sense to make a mounting plate that's a custom length to match your specific airframe so you don't need to mess with spacers too.
Thanks for the offer Dave but my Plan is to make a simple "ring mount" with holes matching the firewall mount my ST 23cc has. This way I can use the "testbed" aircraft Im building to test them both... Once tested I might make a more "formal" mount.
