RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-07-2022 | 05:13 AM
  #687
Raleighcopter's Avatar
Raleighcopter
Originally Posted by Glowgeek
I'm running a Xoar 18x8, engine was already broken in some, I finished the break in. Peak is 7150 rpm set slightly rich. Could be too much prop, I have considered that as possibly contributing to the excessive heat. Retarded timing can do the same thing, finishing the burn too far down the cylinder wall. The total oil content of my fuel is 17.5%.
If this engine can't turn a 18x8 I'll be getting rid of it. 16x8 is not going to do, a 17x8 might be ok.
well if it can't turn a 18/8 on meth, it probably can't turn a 17/8 on gasoline. how much prop do you need for the airframe you're planning to install this engine on?
