RCU Forums - View Single Post - the glid setting on an ARF
Old 11-13-2003 | 12:22 PM
visioneer_one
My Feedback: (506)
Default RE: the glid setting on an ARF
ORIGINAL: cougar27mtr
I hear if you get prop wash and apply it then you get a better ratio... You can buy it any local hobby shop..
Prop-Washâ„¢ is great stuff!
[*] When applied to the exterior fuse and wing it acts as a sloughing agent - dust, glow fuel, castor oil and bug innards don't stick, makes cleanup very easy![*] A small amount added to your fuel-mixture cuts fuel-foaming and allows one to run leaner mixture for more power![*] Shines and protects rubber, plastic, vinyl surfaces![*] Contains a a unique, patent pending UV protection system to help block damaging UV rays![*] Repels mosquitos![*] Freshens breath![*] Whitens teeth!
Only $32.95* In A Convenient 14oz. Size!
*plus $8.00 postage
