RCU Forums - View Single Post - Building a scale 1973 Pay'N Pak from plans
Old 09-10-2022 | 10:06 PM
Hydro Junkie's Avatar
Hydro Junkie
And, once again, work and other things have kept me away from the boats.
Tomorrow was supposed to be a race day but, due to my work schedule, I've decided to pass on the race and sleep in so I can be "somewhat awake" to go to work on the overnight shift. Instead of racing, I'll be spending my prework time working on the Pak. I have made a decision that will make the right sponson transom a bit harder to do. I've decided to make the transom a "sandwich" by using 1/16" aluminum to face it with on the outside, a 3/16" thick plywood center and a 3/16" thick inside aluminum plate with the two inner pieces lightened with lightening holes to keep the weight down as much as possible. I'm still trying to decide if I should screw the inner aluminum plate to the plywood core or just epoxy them together. I guess I'll have to see how well the glue holds the two together and go from there
