RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-12-2022 | 03:27 AM
  #781
Raleighcopter's Avatar
Raleighcopter
I've never looked at it on one of my oscilloscopes because it always works. I just run only the signal wire from the ignition directly to (I think) pin 8 on the nano. I do not attach the ground on the rpm wire when using an rcexl ignition kill switch (which is always) as I'd prevents the kill switch from working.
Originally Posted by Cat 1
Dave, Do you use the RCExl tach output for an RPM feed into OpenXsensor? I seem to be having trouble with getting a good signal there - Its very noisy (high frequency). If I Play with the scope settings I can see the pulse for the ignition but lots of noise on top of it.. Is a filter required?
Im was assuming the signal is an +5v / 0V situation like the Trigger Hall but it seems to be A weak (low voltage/current?) signal. Should be signal to pin 8 and ground to ground correct...
