RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-13-2022 | 07:41 PM
  #790
Cat 1's Avatar
Cat 1
Originally Posted by Glowgeek
Which ignition cutoff board are you using?
Just bench testing Lonnie and no ignition cut-off used yet and I discovered (the harder way) that I needed to have the ground hooked up - After I did- I re-read Dave and Bert's commentary on the kill switch item and deduced it does get a ground from a "turned on" kill switch.
