RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-14-2022 | 02:39 AM
  #791
John_M_'s Avatar
John_M_
Originally Posted by Cat 1
Just bench testing Lonnie and no ignition cut-off used yet and I discovered (the harder way) that I needed to have the ground hooked up - After I did- I re-read Dave and Bert's commentary on the kill switch item and deduced it does get a ground from a "turned on" kill switch.
Grounds through the ign power source not through the receiver unless you have done the BEC mod... with the STD setup using a dedicated ign battery the receiver powers the kill switch logic, and the kill switch then switches the ground of the ign power source.
