Originally Posted by
Dave Wilshere
Balance it with a good amount of fuel. Set up is all std UF since that’s what it is.
I figured that’s what I would do but I’ve seen two different marks for CG. I think one of them is for the older UF with tip tanks. I appreciate the info. I’ve seen a ball on the end of the rod that holds the canopy on. Are you familiar with that and how is it done? Mine is just a straight piece a rod so I figured I might make a 90° bend if nothing else.
