RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-18-2022 | 11:10 PM
  #820
1967brutus
Originally Posted by Cat 1
OK fellas, Need some input... UP sized the jet (twice) and still lean on the top - The throttle is not "dead" with top end opening so I don't think the venturi is overly big and its smaller than stock... I am turning the Large 18x6 wide APC at 7300 rpm (1500ft pressure Alt). With the jet increase (now at .5mm) I am not able to richen to rpm drop and have "no headroom".. if I pull the throttle back 15% - I then can find a bit of tuning headroom.
I have straight pipe stacks and have a pressure nipple in each side - But i'm not getting any tank pressure - tried variations on the theme (blocking one side) but no dice. I am getting black oil into the Tubing up to the Syringe crap trap but no apparent movement when powering up. Im thinking that my pressure fittings are not capturing pressure and acting like static ports.
Other than that its running great - Added an air bleed (conventional) and it pulled the idle mix up and made it less sensitive.. Just have to find some room on the top .. I could keep jetting up but I think its more pressure related.. Im already "big" for comparative jet size - Just need a little more "push"
How is 7300 for Power on that wide APC Bert?
I am also watching temps with a small IR heat gun - #1 cylinder runs about 5-10 degrees cooler at high power but this cylinder does have a bit less Compression "POP" than the other - I think it slowly improving though...
https://www.youtube.com/shorts/tPN3T341974
7300 on the 18 x 6W, basically at lean limit is a bit low, which suggests the air intake is slightly restrictive... Standard carb would allow something like 7600~7700, a bit depending on state of break in if appliccable.
Mine does about 7400 in the "ground-rich condition" that is needed for flight.
You might want to get a pair of .91 FS mufflers... The WILL provide good presssure.
FWIW: back then I brazed one pressure tap in a standard header, for Dave. I did place the tap under an angle, and it seems to work for him,
