RCU Forums - View Single Post - Learning to use a hi-start
Old 09-18-2022 | 11:50 PM
  #84
kazaklisglider's Avatar
kazaklisglider
The bungee is modular and consists of three separate parts:
- Special cut Latex surgical tubing (1/4 inchx1/16 half disc section with high elasticity 400%). Length is 6.5-8 meters (varies depending on application)… perfectly split/cut tubing from fresh production batch ensuring longevity… ends equipped with a strong ring and heavy duty swivel.
- Two separate line reels made of XPS and very practical to use with removable axles and easy engage/release line fittings. Line spools of 25 and 35 meters utilizing high elasticity/ yellow colored 0.6mm line… end fittings easily engaged in pennant and bungee end.
- Nylon pennant… its line ends equipped with heavy duty swivel and a small diameter tow ring.
In actual practice this micro bungee offers easy 5min deployment and retrieval… depending on conditions the short of long line can be interchanged easily thanks to the end fittings…very practical to use/ store ensuring hassle free launches of your mini sailplane… Instructions on proper use and tips on launching/model trimming included.
Only item additionally required is a ground anchor/stake that I deliberately omit from the package as its heavy weight and length would only increase shipping cost… a stake is really a low cost item and easily obtainable on most hardware stores so it’s best to obtain one from your end.
