RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 09-24-2022 | 12:22 AM
  #876
1967brutus
Originally Posted by Glowgeek
Here's another one I've been thinking on. Will the stihl solenoid control airflow? If it will then we could use checked crankcase pressure to the tank and control that pressure with the solenoid used as a programmable bleed off valve . No crap trap, no air pump, no additional battery mah. Hmmmmm
It would... But I have no idea about its longevity or its linearity, Probably with a dry airflow service life is less than optimal (movement and no lubrication) but crankcase pressure always contains some oil mist. That should ensure proper sealing.
I could see that working, but probably you will need an additional sensor to control the actual sensor, because I think the RPM will have influence on the gasflow. Especially with 2-strokes, where the throttle affects crankcase peak pressure.
