Originally Posted by
Cat 1
Many fuel setups in aviation are "pressurized" but never for engine supply directly - They usually use forward airspeed to generate some sort of head pressure on the tanks just to make sure fuel "moves" properly and in some cases (with bladder style tanks) it prevents collapse of the tanks. Cant remember the set pressure (1.5 to 2 psi I think) but the popular "king air" aircraft I have worked on, have a intricate little vent system that has a couple of "heated" tank vents that are angled into airflow and on the bottom of the wing .
Most RC tanks get pressurized but its only .5 psi - Some (YS engines) get pressurized much more. A small fuel pump would be doable (RC turbine) but I think control of pressure/flow would be an issue. It works in the turbine as its the "driver" and everthing else happens because of the amount of fuel applied - with an IC engine - it must follow a number of other drivers.
Thats exactly how the wing tanks are vented on the J3... with a small header tank in the nose... full scale, the header tank is tiny, just a tube reservoir.
These are the tank covers to the model J3... fully functional vent system... which doubles as the fill and overflow as well.
Please don't re-post these, thank you.
https://ibb.co/6YMdzWL
https://ibb.co/4MrSL27
https://ibb.co/zSf2gXB
