Yes, remove the diaphragm cover, press the lever down and rock the engine back and forth over compression. This will confirm that the pump is working and vent the air trapped between the pump outlet and the inlet valve. If you get fuel the problem is on the diaphragm side, no fuel problem is on the pump side, pump gasket, pulse port, bad fuel tube, etc.
