Originally Posted by
David Gladwin
The first 20 minutes exploring these servos was highly impressive.
Tightest gears I have ever experienced, even on some very fine servos, and with a large amount of very valuable data via P2 bus facility.,… and NO servo buzz, just a slight hum when delivering high torque !
Idle current , no load, .04 amps.
Absolutely superb devices, will be using a lot more of them with my Core.
David Gladwin
So your point is ….. !
David, some transparency is due here - either you are given these and just sprout total BS to keep someone happy OR you are dreaming when you say "tightest gears I have ever experienced" THESE ARE MKS 550's. You mention you have used some high end JR's (Great servos) as well as Savoy, again a great servo. Rick and the gang are not doing anything to them to make better than they actually are - you do know this? It's not like it is a MKS case, new PG drivetrain and pcb.
I can imagine you would do a placebo test - get given the placebo with the words "Placebo" on it and then still argue it worked - and was actually better than the real product.
