Originally Posted by
jvaliensi
The interface is smooth and even on both wing and fuselage.
I think either the top of the wing is too fat or the wing pins are set too low. Or the forward fuselage holes are drilled in the wrong spot.
Have you run in to this before? Since all the models come out of the same mold it seems an unlikely situation.
I'm thinking to sand the wing pins and sand the wing saddle in the fuselage.
Not seen it before. Front pins are a possibility. Unusual for CARF though
