ORIGINAL: JoeAirPort
This looks really cool but another guy had problems with retracts included in an ARF. Seems that they were a little weak for 60 sized plane...
The .60 size WM Spitfire comes with heavy duty landing gear wires (close to 3/16" in diameter). I had well over 100 flights on mine and did not encounter a single problem with the retracts, even from a grass runway. If you settle the plane down gently onto the runway, then you will never have problem.
