Originally Posted by
Glowgeek
I thought I made it clear that I won't transfer an engine from the bench to a plane until it runs right. That means from a full tank to an empty one, period. If that's "making too much of things" then so be it. Don't worry, I'm not flustered, a bit perturbed with it, yes, but not beaten. Eventually the problem will be found, on the ground.
You have now... you'll figure it out with that determination
