RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 10-06-2022 | 01:44 PM
  #975
Glowgeek
Originally Posted by Raleighcopter
Are you sure you're not getting small air bubbles leaking in where the tubing is connected to the solenoid or even at the tank? I usually double up the tubing at the nipples.
Everything holds pressure solid at 3 psi, no leak down. That's with the carb line plugged and applying pressure through the muffler pressure line.
Bubbles in the fuel line stopped with the installation of the heat isolators.
