Originally Posted by
F1 Rocket
Depending on the age of the kit the servo pockets in the stab might be a bit tight for most of the “standard” full size servos available today. The 8411’s are a bit thinner. Later kits have a little more room. I’d consider the MKS HV747 (mid size) or MKS HV1200 (full size) if you have room. The 747’s will require a bit of adaption to the mounts but this is easy to do. If you need lower voltage servos look at the MKS DS1220.
If it was mine another option for the older UF Would be the MKS 747R would much easier to adapt to the panels…..
