Tony,
I suspect that a fog machine doesn't get very hot and the "smoke" you're seeing is mostly water vapor. That's not to say that this stuff won't produce smoke (or steam) when exposed to 800C turbine exhaust.
As an experiment why don't you put some in a spray bottle and shoot it into your exhaust stream to see what happens. That way you won't be risking your pump or nozzle.
Joe
