Originally Posted by
joeflyer
Tony,
I suspect that a fog machine doesn't get very hot and the "smoke" you're seeing is mostly water vapor. That's not to say that this stuff won't produce smoke (or steam) when exposed to 800C turbine exhaust.
As an experiment why don't you put some in a spray bottle and shoot it into your exhaust stream to see what happens. That way you won't be risking your pump or nozzle.
Joe
+800*C Humm none of mine go that high, and in flight full throttle they never even go to 600*C at idle some go to 250*c and number I have seen from telemetry post flight was around 450*c generally in flight. For this purpose I’m looking at a K210G2 (700*c is the max, and pretty much for start)
