RCU Forums - View Single Post - Leopard 1s
Thread: Leopard 1s
Old 10-27-2022 | 05:14 PM
Durahl's Avatar
Durahl
Originally Posted by RichJohnson
How did you fit the thickness of that bearing race between your gepeard turret and the hull? Did you cut out the bottom of the turret to install it?
I cut both the Turret and the Hull:
The respective Turret Ring Parts were mounted flush into the Upper Hull / Lower Turret parts after cutting the original Turret Ring out with the help of a Stencil.
Gaps between them were filled with micro sized glass beads and then Superglued ( after backing the rear with Masking Tape ) together.
Video of it in action:
Tanker1966 (03-08-2024)
