CG Question.......
I understand this is a old topic,,, I picked up a TF Staggerwing. Just a airframe.
I DID get the manual with it and read many post on how to balance the model 5 1/2" back and inverted.
I am VERY shocked to find out I need to add a bit over 3# to the nose....... When building it I took note to install all the equipment forward in the fuse
Is 3 pounds correct??? I did not remove interior plywood bulkheads...
Thanks in advance for your opinion..
Hoss
