RCU Forums - View Single Post - Top Flite Staggerwing
Old 11-04-2022 | 07:51 AM
  #1963
rowdog_14's Avatar
rowdog_14
Originally Posted by Lil Hoss
I understand this is a old topic,,, I picked up a TF Staggerwing. Just a airframe.
I DID get the manual with it and read many post on how to balance the model 5 1/2" back and inverted.
I am VERY shocked to find out I need to add a bit over 3# to the nose....... When building it I took note to install all the equipment forward in the fuse
Is 3 pounds correct??? I did not remove interior plywood bulkheads...
Thanks in advance for your opinion..
Hoss
What engine are you using? I used an OS 160 FX on my first one and it needed a lot of weight. I had a large battery and probably about 20 squares of 1/4 lead.
My current has a Saito 170R3 but I have not balanced or flown yet.
