RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 11-05-2022 | 06:13 PM
  #1112
Cat 1's Avatar
Cat 1
Hey Bert, Will trade you wet grass clipping for this mess... Mother Nature has unleashed a Classic Saskatchewan Blizzard on us to kick off winter here lots of snow and wind and drifts are building!!!
SO.... I'll hide in the shop and Play !!!
Did a bit more work on the e-pressure control - I have re-done the code to allow for a RC channel input to drive a curve - Just like the solenoid controller, while still having the underlying RPM driven pressure curve. What this means is that the engine rpm will drive the main curve but it can be manipulated on a curve mix just like the pressure controller. The RPM curve is the master though and will always increase as engine speed increases (on an exponential curve that's settable) Im hoping to test it out on the OS .37SZ just on the stock carb... If this works it would be a very simple install. Here is a video that might show it better.
