RCU Forums - View Single Post - Electronic solutions to modifying glow engines of all sizes to gasoline
Old 11-06-2022 | 01:13 PM
  #1117
Glowgeek
Originally Posted by Cat 1
Your correct Lonnie... Master curve is the RPM following one and is set in the script by Max RPM and an expo value (can curve the response based on this setting similar to expo on our radios). This strictly is more RPM=More fuel. Then a single input channel can bias the output of the first curve up or down based on a radio curve like our solenoid setups. The only other parameter is the bleed needle which is simply set to a "max pressure" at full pump speed (100% duty cycle).
Got the snow all cleared out today so hope to be able to get this closer to running on an engine to see it its viable or not.
Chris
As fast as the pump increases pressure and as fast as the relief valve bleeds it off I don't see why it wouldn't work.
With an airbleed or 2 needle carb setup I'm thinking you won't need more than 0.7 psi to allow things to work right. That may be a good thing, allowing the relief valve to be opened more, speeding the release of tank pressure on throttle down. Hypothesizing.
