Originally Posted by
Cat 1
One issue is the HS needle is less than 1/2 a turn open. Its a fairly steep angle needle and one click makes a bit difference in mixture - with the pressure (and the bleed) I was Able to get it running well though.. Any tips on what to do to make the HS needle less critical
Three options:
1-Lower pressure range (this will make the influence of the self-controlling properties of the engine more pronounced because carb vacuum can play a larger role)
2-modifying needle taper while maintaining original thread (this will leave slop in the threads unchanged and might make the needle less critical but does nothing for accuracy)
3-finer threading (IMHO best option because it will also reduce slop and make settings also more constant)
