Originally Posted by
Raleighcopter
chris, are you using the air pump for fuel pressure in conjunction with the solenoid or in place of the solenoid? my gut says we may want both but i'm not sure here since i haven't played with an air pump and don't currently have one.
Dave, I have done both now - Used it for muffler pressure only and then added the curve function for the ability to do the curve like the solenoid. Both work but the solenoid is a finer control in my opinion. I think both options are viable though but need to get some "air testing" in to know for sure. I think the code I sent you was RPM only and didn't have the curve - The code for my curve is messy but it works - Im sure you could do better but I will try to send it for reference.
I am working on a "package" for the unit to make it neater.. Should have something soon.
