Originally Posted by
wing13z
Hello, I just did my maiden flight a few days ago. I noticed there is a pitch down when I apply full throttle!!
I did check my my turbine and the pipe they looks centered and straight!! Even my elevators looks normal! Did any one had the same issue? and any idea to fix that?
Im planning to do a mix between my throttle and the elevator to fix this issue, but this is going to be my last solution, I would appreciate any ideas and suggestions.
Hi
I’m pretty certain I do not have any pitch power couple on my airframe.
The elevators have a couple of mm of down for trimmed level flight.
Perhaps double check your CG position.
ATB
Phil.
