RCU Forums - View Single Post - Sebart 2m Avanti Experience?
Old 11-22-2022 | 04:15 PM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Originally Posted by DUCMOZ
Sorry to jump in but I think the one Zeeb is talking about is different than the one you are asking about. The one you are asking about is 1.9 meter version which is new. The one Zeeb is talking about is the original version which I believe was slightly larger. (maybe 2.1 or 2.2 meter). if you search you will find the thread for that one which if I recall correctly was started by Dr. Scoles.
Behzad
I think you are confused. My model was the original 2M Avanti S with a composite fuse and built up wings.
Seba cut a deal with Ivo Krill for a version with composite wings and provide retrofit available wings for the first versions. The first thing Ivo did was to increase the size of the model to 2.1 and make design changes that would prohibit the use of the new composite wings on the original.
I've not seen anything posted by Mike concerning a 1.9M version of this model. IIRC, he did do a write up on the "mini" version of this model which was designed as a ducted fan which could be converted to a Turbine.
