Used Dual Sky Brushless Motor XM6360EA-10
Up for sale is a barely used Dual Sky Brushless Motor pulled from my Blackhorse Fi-156 Storch. No flights on the motor, only test stand runs to help with prop selection. Also included is the Great Planes HD Brushless Motor Mount. This system really simplifies your motor installation, and is fully adjustable to fit your fuselage/cowl. Here are the specs for this brushless motor which runs on a 10S system:
KV: 218RPM/V
Alias(Stator diameter, Magnet length): 5330
Weight: 627g
Diameter: 62.4mm
Length: 59mm
Diameter of Shaft: 8mm
Mounting holes pitch: 44/44mm
Slots/Poles: 12,14
Idle Current(Io) @10V: 1.56A
Resistance(Ri): 23mOhm
Cruising power[8 mins]: 1694W
Bursts current[15s]: 83A
Peak power[15s]: 3080W
Recommended ESC: XC10036HV
Setup 1(No. of Cell, Prop.): 10S, 20X12
Setup 2(No. of Cell, Prop.): N/A
Max. weight of sport models: 8.5Kg
Max. weight of 3D models: 5.6kg
Replaces/equivalent to: .140-.160 2-stroke, or up to .200 4 stroke, or 33cc Gas Engine.
Buyer pays for shipping from Simpsonville SC 29681.
Thanks for looking!
