Originally Posted by
Skunkwrks
Sound like a starter issue, is it a brushed or brushless motor?
Thanks. The engine is older (even though nearly zero-time) so I assume brushed. The starter motor has seen almost no use since new though, so I am hopeful that brushes are not the issue…unless they are prone to age-related corrosion even when stored in a controlled environment?
All help welcome, so thanks again.
