Originally Posted by
Outrider6
I am currently building a Goldberg Ultimate from a set of plans and a stack of balsa, plus the landing gear, canopy, cowl and wheel pants, and all hardware, which I had to source aftermarket. I am using very little lite ply in mine, to save weight and actually be stronger, but not as "tough". I have re-designed the top wing attachment to use two screws into the bottom of the top wing, instead of the pin as designed in the kit. I am using two wing servos in the bottom wing, and the upper ailerons will be driven by connecting rods. My outer wing struts will screw onto the sides of the tabs in the wings (similar to the kit). I did think about making the wing tabs go into pockets on the struts, but didn't want to add complexity.
I can't be certain from your description, but it seems that yours might be a modified original kit. If you are able to post some pictures that show the internal structure, those of us familiar with the plane might be able to tell more.
I tried to post pics but I do not have enough posts yet to do so.
i just tried again and was able to add pics
