Originally Posted by
rams
After soaking in the heated antifreeze, what is the next step? Do you rinse off the antifreeze? If so what do you use to rinse with? Do you need to apply a lubricant? Jim Nordly
Scrub the parts while still hot/warm with stiff plastic bristle brushes. Fingernail brushes, tooth brushes, gun cleaning brushes etc work good. I use denatured alcohol while brushing. Oiling after cleaning is a good idea.
