RE: EDF combat
If your talking about impeller strength, well, you're right some impellers aren't that strong. However there are ways to reduce the G stress.
-One is to make the fuselage's inner diameter match exactly the outer diameter of the Ducted Fan's case
-Another possible idea is to use a more efficient and balanced motor like a hacker and such
-You could also possibly make the impeller mount stronger somehow
