RCU Forums - View Single Post - AMA Mar Rationalization of Breaking Rules
Old 12-30-2022 | 05:35 PM
  #53
Hydro Junkie's Avatar
Hydro Junkie
Originally Posted by ECHO24
It's the one with the head blowing up by your new best friend, Jabba the troll. That would be flagged and blocked anywhere else, just like other hundred or so troll posts. And you throw a fit over couple of salty comments (now edited). What else would you like to be called when all you know about RC flying is whatever Franklin tells you? Boats and square dancing are your thing. You're on a model aircraft forum.
I know this is a model aircraft forum. You must think I'm totally stupid to not realize that. For the record, I built my first plane, an OS 25FP powered Kadet Jr, back in 1986. I have two more under construction as well, both from plans since the kit is no longer produced. When those are done, I have three more large aircraft to build, those all being 50cc sized. Haven't decided on which one will be first, just that I have plans for a Katana, Edge and Pitts model 12. They are all basically on the back burner until the FAA gets its act together with the RID requirements. Neither of the Kadets are going to be stock builds since I'm not restricted by factory made parts. When they are all completed, then I'm looking at a WWI warbird, just for the fun of building it.
