Originally Posted by
Hydro Junkie
I know this is a model aircraft forum. You must think I'm totally stupid to not realize that. For the record, I built my first plane, an OS 25FP powered Kadet Jr, back in 1986. I have two more under construction as well, both from plans since the kit is no longer produced. When those are done, I have three more large aircraft to build, those all being 50cc sized. Haven't decided on which one will be first, just that I have plans for a Katana, Edge and Pitts model 12. They are all basically on the back burner until the FAA gets its act together with the RID requirements. Neither of the Kadets are going to be stock builds since I'm not restricted by factory made parts. When they are all completed, then I'm looking at a WWI warbird, just for the fun of building it.
anyone can see he's just grasping at straws with his trollish .."BUT but but you aren't a plane flyer..!!!."
As a "regular" at this forum it's a safe bet you are more informed about what's going on at AMA /FAA HQ than the typical AMA member.
