RCU Forums - View Single Post - Build time / repair time to combat time ratio
Old 01-02-2023 | 09:37 AM
Old Erkki
Default 1Hour / one minute
Greetings from Finland
I am slow builder it takes about 20 hours to build one WW II combat plane. Some people say that they can build simple combat plane in five hours. Then the work have to be serialised. And usually they are electric versions.
The heat lasts 7 minutes and I am happy if plane survives three heats so one building hour for one minute of combat flying.
Worst case is when having a straight hit and all the pieces fly to different directions and pilot have to search engine, tank, receiver, battery and servos separately. After some not so serious hits plane can be repaired. Broken wing or fuselage can usually be repaired with polyurethane expanding glue. If damage is too serious the it is possible to save and recycle some part like tail feathers, aelerons, engine, electronics etc.
That Dauntless was on the limit. It was possible to repair, but I decided to recycle parts.
Spit was easy to repair just half of hour work and it is still able and ready for next heat. Only problem is. that I kind of love it and do not want lose it.
Old Erkki
