RCU Forums - View Single Post - 1/18 chassis build need motor/gearing and tires for
Old 01-15-2023 | 09:41 PM
  #34
testfly
Default Final Chassis Design images
Here are some pictures of the final design of the car I have created. It shall be know as the "G-10 3D Sport Racer". AKA "G10 3D SR"
The G-10 parts are cut from .062 G-10 FR4 material using a .0625 bit at 15,000 rpm and 15 ipm.
The Chassis bolts together using 3mm hardware. All nuts are nylon lock nuts.
Note the body post are replaceable. They can be printed to match the car color.
Rear axle bearing OD is 9mm. (The size of the bearing hole cut in the chassis) I use a 3x7x3 for the front wheels. (All bearings are flanged bearings)
The body was formed from .062 PETG plastic. This makes the body strong. Note the thickness at the body edge.
Note the body thickness at the edge.
The chassis is designed to run brushless or a slot car motor.
Mount this rail on the left side as shown if you want to run a brushless motor setup.
Here is a look at the slot car motor bolt pattern. If you want to run a slot car motor, place this chassis rail on the left side of the car.
That is about it on the G10 parts.
More information on the 3D printed parts coming soon!
