Originally Posted by
astrohog
You guys should check out this place.
Fiberglass Supply. They are probably a little bit farther for both of you, being located in Burlington near the Skagit Airport, but they offer a pretty good selection of composites, resins, gel coat, etc. I think they also have some balsa core.
Astro
Thanks for the tip..!!
I would rather go to Burlington than South Everett.
Years ago I swore off doing any more extensive FG work....but there are times when the "pull" is too great to buy $500 bucks worth of supplies so that I can build a plane that is 2% better than if it were made of all wood...
