RCU Forums - View Single Post - 1/18 chassis build need motor/gearing and tires for
Old 01-26-2023 | 05:33 PM
  #47
testfly
Default Updated wood plug
Here is a look at how I updated the front of the wood plug.
I mounted the plug back to the cnc machine and created a tool path of what I wanted.
Looking good.
Then I cut it down to the top of the buck. I then gave it a good sanding and it was ready for a test pull.
So it was time to heat up some PETG.
Almost ready.
Here is a look at the pull while it cools.
The front end looks good.
Here is the pull with the plug removed. Notice I also removed the lines in the windshield. It just needed a bit more sanding.
I pulled a second body to be sure the plug was good.
The fit is perfect.
Here I have cut the body before painting so I could check the fit.
Here are a few more images of the result of my efforts.
That looks pretty good to me.
Yep that will race!
