RCU Forums - View Single Post - Spinner fitting problem
Old 02-02-2023 | 01:56 PM
model14
Default Spinner fitting problem
I am having difficulty fitting plastic spinners (specifically a DuBro 2" spinner)) to my electric motors. On the motors I use, the prop is attached using a collect that is locked down when the prop shaft nut is tightened. However, the threaded shaft extending from the collect is not long enough to accommodate both the spinner backplate and the prop hub. If you know of a solution, I would appreciate hearing it. I am building a Phil Kraft Flea Fli from plans and I need the spinner look.
Thanks.
