RCU Forums - View Single Post - Let's try to build a home made Kevlar fuel tank!
Thread
02-04-2023, 07:14 AM
2
sandrocacciola
1 Post
Slightly reduced to have a capacity of about 3.5 liters (more than enough for my 120N turbine) the main part of the tank has been designed in 4 shells (two halves for the lower part (which also has a flare where the upper to close the two shells with a perfect joint) and two halves for the upper one to allow the shot to be easily extracted from the master.
Once the files were obtained, I started to do some printing tests on my Artillery Sidewinder X2 to find (I use “Cura” as the slicer) the right parameters that would allow for the smoothest internal mold surface possible. Once I found the optimal configuration I started printing the molds. It took about 55 hours of printing to get all the pieces and at this point I dedicated myself to the finishing work.
(continued)
Reply
Like
sandrocacciola
View Public Profile
Send a private message to sandrocacciola
Find More Posts by sandrocacciola
View iTrader Profile
