Jeti. It has enough volume on the speaker that I can actually hear the voice callouts. I really like the 3 axis accelerometer feature! You can set the timer to use the accelerometer so that to find out, to the second, how much flight time remains, you simply tilt the transmitter! Also has "Assist" receivers which have a built in 3 axis gyro that is so easy to set up that it's almost foolproof. Gyro setup is done completely on the transmitter and is similar to a software setup "wizard" that steps you through everything. I have yet to find anything that the Jeti system cannot do. There are literally hundreds of videos out there on Youtube for the Jeti radios that are far better than any manual ever written!
It is so easy to move switches to other positions or change the types of switches. Unlike with some brands, you don't have to send it anywhere to have switches replaced. Any channel can be used for any function you choose.
