Originally Posted by
ledd4u
That’s a lot of data to stuff into a 2.4 ghz signal. Latency effects, super fast micro electronics probably needed. Telemetry data stream would probably congest the signal? Data packs missing etc.
And you have actual figures on this or is this just an assumption?
You may be surprised that PowerBox receivers actually transmit their telemetry information back to the Tx at the same RF power as the transmitter sends to the aircraft... Also the RF bandwidth used by different systems is not the same so different systems have different data speed/latency capabilities.
The overall telemetry performance criteria was a main design element during the development of the PowerBox P2BUS and no other system currently comes close to the same performance in this area.
At the end of the day...there is no 1 single 'Best' radio out there, they all have thier pros and cons.
You really can't go wrong with any of the top tier brands - They can all fly your aircraft well....
