RCU Forums - View Single Post - 1/10 RC Formula 1 Cars...lets see'em
Old 02-26-2023 | 06:22 AM
  #936
rc-kramer
Smile Resurrection of an old thread...
Originally Posted by Vyger
OK, I got some time tonight to throw some stickers on the Sauber. I thought I'd start with a clean picture of the car before any stickers get applied. I also decided to take it up a notch from the stock Tamiya supplied stickers.
This is the plain car with just paint.
As I mentioned I decided to go a little extra so I opted out of the simple plain black stickers that go on the sides of the front wing. I picked up a sheet of Tamiya's new Carbon Fiber Pattern sticker sheet. It's not completely true to scale but it gets the point across and has a nice effect.
I used some rubbing alcohol to clean the wings off, removing any oils and fingerprints. To get this to work I pealed the backing up and laid each of the wings on its side and pressed down. I used the exacto knife to trim along the edges and cut to fit.
Because the rear wing is adjustable I cut an X pattern in the sticker once applied, then used a quetip to push the sticker in. This helps prevent the sticker from rumpling up when the screws get tightened.
I used the same sticker sheet for the front wing.
With the carbon backing on I was ready for to apply the kit supplied stickers to the wings.
I also decided to throw some paint on the front wing to add that little bit extra to it. I used Tamiya Semi Gloss Black on the inside of the front wing. This should give it enough reflection to simulate that epoxy carbon look. I taped off both wing elements and applied a few coats of paint using the wide tipped brush mentioned earlier.
I didn't get a chance to finish the rear wing. I still have apply the white stickers to the upper wing element. But it's late, I have work in the moring, I'm tired, I'm hungry and I'm done for the night. Below are the pics showing the car with the wings mounted and the cock painted.
Hi Vyger, long time no post!! Just been looking through this thread for an old photo I'd posted about a decade ago lol, only to find it's been watermarked by Photobucket!!
Anyway, seeing this Sauber C12 reminded me I recently managed to pick up a BNIB genuine body set... Not cheap n it will probably remain in the box, although I have another couple of builds in progress, too...
Would be great to hear from you n see what you're up to these days!
Cheers, Kramer 🙂👍
